Sam_Spade
Jun 14, 2016Explorer
Harvard wrote:
Just a heads up in case you have handling issues with your Ford E Series. Many of the E350/E450s are delivered with to little front end caster. Having too little front end +caster will manifest itself as "loose steering" (and wandering) at highway speeds. FYI
And the fix makes a REMARKABLE difference.
In addition to your check list:
Get a multi-meter if you don't already have one and check the coach batteries.....both while plugged into shore power and when the truck engine is running. In both cases, it should be at least .5 volts higher than just the batteries alone. (for instance, battery not charging = 12.6; with external power or engine running, at least 13.2).
38,766 PostsLatest Activity: Jan 10, 2026
