rjstractor
Jun 14, 2016Nomad
Baja Man wrote:
1. Definitely will be checking battery water levels and using distilled if needed.
2. will be adding a back up camera when I return from this trip (if I don't chicken out!)....just not enough time to add it now
3. Is it SAFE to run generator when traveling?
4. Is it SAFE to run refer on propane while traveling? Would like to keep food at safe temps as it will be HOT!
5. Should I run with tow/haul mode ON?
#3, yes, did it for years. The cab AC should do an ok job of cooling the front of your rig but if it's very hot or you want the rear cooled, run the house AC. Fuel burn will be around 1/2 gallon an hour which has minimal effect on gas mileage.
#4, yes, did that for years too.
#5, experiment with it. A 31' motorhome is always "hauling". Towing a lightweight boat will have very little effect on performance. Nothing at all like hooking a heavy RV trailer to a pickup.
Before my first motorhome I had a travel trailer, and found driving and setting up the motorhome to be much easier. With your fifth wheel experience you have nothing to worry about.
38,766 PostsLatest Activity: Jan 10, 2026
