j-d
May 31, 2014Explorer II
I wonder if every TriMark entry lockset has the problem alluded to above. There was a flurry of problems with them, documented here on RV.net. Advanced Search using "trimark", "Class C" and "Archive" will show that the culprits were Model 60-650, not the current OP's 30-900. Not to say TriMark doesn't make them all the same way, with a pot metal piece where steel belongs. I looked at ours, saw it wasn't 60-650 and called it Good. Maybe I shouldn't but so far so good. Also, coach has a residential deadbolt in the door, above the TriMark. That's the only lock I actually lock with. Don't know if that reduces the risk of lock-out/lock-in...
