trnfla's avatar
trnfla
Fixed my Trimark door lock, I think...
I have been having a issue with my trimark 30-900 door lock where the paddle handle would sometimes not open the door.
After researching a replacement handle, I was directed to undo the handle to try to find a certain number to see which lock I needed to purchase.
When I was trying to get the lock apart I saw how the locked worked and realized that it looked like the adjustment nut (access behind black plastic plug on door jab) on the lock assembly was to loose making the paddle handle to have to be pulled to far to trigger the lock release.
I reinstalled the lock and adjusted the nut so now the door opens when the paddle handle is only moved about a quarter of the way.
Hopefully this fixed my problem.
FYI, this is another great reason to make sure that you either keep the front cab doors unlocked or a front cab door key hidden outside the camper when camping. Saved me the hassle of how to access the camper.
I will let you know if this solved my problem, doing a number of trips this summer.
  • Sounds like you may have got it fixed. But a bit of advice, from experience. If the thing breaks, in the door closed postion. It is an absolute nightmare to get out and replace.
    If it does not work perfect now, or starts to act up at all. I would spend the 90 bucks, and replace it before it blows up. Sure wish I had.
