ronfisherman
Jan 11, 2020Moderator
clotus wrote:
UPDATE: So although I had initially checked the bulbs, I only looked at the filament. Well, after checking the fuses and relays I pulled the bulbs and wouldn't you know they were both corroded at the base! Replaced the bulbs and BOOM problem solved!!!!
Before you seal the light up you may want to put some protectant on bulb and connectors. One product is Camco 55013.
38,782 PostsLatest Activity: Sep 10, 2026
