- anbilExplorerThanks for the suggestions. We are working them now,
- Executive45Explorer IIIPerhaps it's related to THIS? Was this corrected? If not, you need to start from square one.....Dennis
- 2oldmanExplorer IIOwner's manual?
- If you have a Heart/Trace/Xantrex system. Disconnect 120 power to the RV. Disconnect the Large 12 volt positive cable to the Inverter. let sit for 15 minutes. Reconnect the Battery cable and then reconnect 120 to the RV. That resets the Inverter and your problem should be gone. Doug
- MountainAir05Explorer IIMight help with a Name, model of unit.
38,776 PostsLatest Activity: May 15, 2026
