Jayco-noslide's avatar
Jul 24, 2017
Flat towing Focus
We have a 2003 Itasca 30 footer with the V-10. Presently flat towing a Chevy Sonic (2700 lbs) and thinking of going a bit larger to flat towing a Ford Focus hatchback (around 3000 lbs.). Wondering if the 300-400 lb. increase will be noticed. I know we will have to go from no braking on the Sonic to braking for the Ford. Wondering if the V-10 will be up to the task in mountains, etc.? Do you have to disconnect the battery cable or anything with the Focus, auto. trans? Have seen similar MH towing much heavier vehicles but that doesn't mean it's a good idea?
  • We tow a 2015 Ford Focus Titanium 4 down with the 2.0L engine behind a 32' Class C E450. The transmission functions like an automatic but it is actually a manual transmission that is controlled by electronic clutches. It has a keyless ignition system. To tow I (1) push the ignition button, (2)push the brake peddle and (3) shift the transmission selector to Neutral, the display tells me the transmission is ready, (4) push the ignition button again. The last step is to (5) disconnect the negative battery cable. I put a battery switch on the negative cable to make the disconnect easy.
  • what does the focus owner's manual say about towing 4 down?
    bumpy
