Abqtiger wrote:
We are considering purchasing a Jeep Cherokee for flat towing. The dealer recommended the Trailhawk. I need an SUV for business. Does anyone have comments pro or con re the Cherokees? Is there a better SUV option of similar size?
be certain that the vehicle can be flat towed. that is not accomplished by asking the sales critter. check the 'Recreational Towing' section of owner's manual for that specific model to be certain. if still unsure contact the manufacturer.
next, be aware of the curb weight of the Cherokee. that's the weight of the vehicle with a full tank of gas but otherwise empty.
then you need to know just how much weight your MH can
safelytow. in general, the maximum amount of weight you can safely tow will be the lesser of the following:
- the GCWR (gross combination weight rating) of the MH minus the actual weight of the MH as it is loaded for travel (includes fuel, fresh water, food, clothing, people, pets, supplies, etc.)
- the weight rating of your tow bar
- the weight rating of your hitch
this is why it's vital to know what your MH weighs as it is loaded and configure for travel before choosing a toad. Your MH will not collapse if it is overloaded but you will experience handling issues as well as longer braking distances and accelerated wear on suspension, brakes, steering, etc.
good luck. jeeps are great!
