Mondooker wrote:
I just got off the phone with the service department and sales department of a local Jeep dealer and found out that the only Cherokee you can 4 down is the TrailHook as its the only one with the 2 speed power transfer unit.
The 2016 Dinghy Guide says the Compass and Patriot can be towed 4 down but the dealer said that is not correct. Maybe its the difference from 2016 to 2017 models?
It's seems like the vehicles you can tow 4 down are becoming fewer and fewer!
I think you received some bad information. If I were you I would visit a dealership and ask to see a Latitude or Limited with an AD II transmission. When they show you one, look at the center console and you should see the letter N with a small concave button next to it. Depressing this button with something like a ball point pen will put the transfer case into the neutral mode, which allows the vehicle to be towed four down.
I would then suggest looking in the User Guide for the complete steps to perform to put it into tow mode.
Also be aware that you will need the optional Mopar towed vehicle wiring harness.
