thoorn
May 09, 2013Explorer
Fleetwood bedroom slide alignment
New to the forum and have really learned a lot so far. I just picked up a new 2013 Fleetwood Jambore Sport 31M. After closer inspection, I noticed that the bedroom slide doesn't close completely on the side closest to the rear of the coach. There is about 1/4 inch gap between the seal and the outside wall. The side to the front does seal tight, so it is like it is crooked. The track for the slide is enclosed under the bed, so I can't see any exposed track when the slide is out. It is a single track, in the middle of the slide too. I checked where the motor and gear assembly are and there doesn't appear to be any adjustability there. Does anyone know if it is possible to adjust the track so that it closes properly? The dealer I bought it at is almost two hours away, so if there is a relatively simple way to adjust, I would attempt myself.
Also, it doesn't appear to leak, as we just took our maden voyage with it, and it rained almost the entire five hour drive home.
