timmac wrote:
rcarpe06 wrote:
There is one question in regards to handling; with the load G tires, and stiff Bilsteins, any small bump, crack or joint in the road was like a big Bang. One stretch of freeway had so many cracks/joints, the nav unit on the dash was moving around some. Will Ride Rite airbags help with the absorption of this? I would think that they would help to 'cushion the blow' so to speak. If so, front, rear, or both.
Any input here is greatly appreciated.
Yep get rid of the bilsteins they are to stiff of shocks, get the Monroe RV shocks they are softer, also airbags will help as well.
Example as to the shock websites, Bilsteins are gas charge at 360 psi and the Monroes are gas charged at 80 psi, guess what shock rides smoother..
Will the airbags absorb enough of the blow to justify the $700 purchase?
