jim427's avatar
jim427
Fleetwood dash A/C evaporator access
1999 Fleetwood Discovery. Looking for help from anyone who has had to replace or work on the dash A/C evaporator. How do you get access under the dash? I cannot figure out how to remove enough of the dash to get to the evap box.
  • I have 2001 Bounder model 39z diesel pusher. Dash does not need to be removed.lower half of ductwork that houses evaporator comes out. The leak was actually the pressure switch next to evaporator.. Mechanic removed evaporator housing in 20 min. Pictures available if needed.
    • Elmerj's avatar
      Elmerj
      I would like to see some pics!!  Please!!!
      • way2roll's avatar
        way2roll
        Navigator II
        You are responding to a post that's 4 years old and cookieman hasn't been on here since. You may want to post your question in a new topic.
  • On my 05 Fleetwood Expedition, you take the defroster vents off, take out the screws hiding under button covers then the entire dash top comes off. We had to replace the thermostat in the evaporater a few years back. Denso has schematics and wiring diagrams on their website. Fleetwood sent me mine.
    • pjs25's avatar
      pjs25
      Hi Big Katuna , I have the same RV and need to replace the evaporator which will require removing the entire assembly , can that be done by just removing the dash top or will I have to remove the whole dash.    Thanks pjs25
      • way2roll's avatar
        way2roll
        Navigator II
        This post is 5 years old and BigKatuna hasn't been on here in 4 years. You might want to start a new topic with your question.
