Colo_Native's avatar
Colo_Native
Fleetwood Fiesta
I have an 2008 Fleetwood Fiesta and I was wondering how to fill the H2O tank when hooked up to city I can't find a valve to switch anybody know if it is even possible, also would you recommend leaving the water pump on all the time or not, it is a demand pump.
  • I also have the 2008 Fleetwood Fiesta. The gravity fill water port is to the left of the entry door, behind a locking square access door. To my knowledge you cannot fill the water tank from city hook up via a re-direct switch. I also only leave the water pump on when dry camping. If I'm at a rest stop while on the road and i need it I switch it on and then off again before hitting the road.
  • I have a 2009 Fiesta and I don't know of any way to fill the water tank other than through the little door on the passenger, as mentioned before.
    As for the water pump, if I am dry camping I just leave it on, but if I am traveling or it is sitting in storage I usually turn it off.
  • The owners manual said there is a valve to fill the tank, but I can't find it( maybe it is a generic writing book) and I know you don't need the pump for city
  • I have the 2007 fiesta you can't fill with out putting the water hose in the holding tank door.There no valve for that.Look for a small door on the outside of the M H.Mines is on the passanger side.
    I never turn my water pump on when hooked to city water.
