- CG_DawsonExplorerAgree with othertonka, think it's on the turn signal. There should be indication on the fat portion of the lever indicating high/low beam control.
- othertonkaExplorerI believe it is on the turn signal arm, you pull the arm toward you to get high beam and push away from you to return back to low beams.
Or pull again to get low beams. - mcarp45ExplorerThanks for the help, I'll pull harder on the wiper control arm
Mike - Welcome to RV.net!
My 1993 on a Chev p-30 has the dimmer switch on the turn signal lever. You must pull a little harder then you would expect. - fyrflieExplorer IIII would guess its either a button on the floor or part of the turn signal.
Try pulling back on the turn signal lever and see if that works.
Good Luck.
38,769 PostsLatest Activity: Apr 24, 2002
