Jack_Pine's avatar
Jack_Pine
Fleetwood Jack Failure
2016 Fleetwood Excursion 35B Power Gear Jacks
Went to put down jacks, did not seem like they were working. Went out and looked under coach and all the jack fluid was on the ground. Don't know if motor failed or hose. Jacks remained up.
Was going to drive it to FL and take it to dealer I bought from for some other issues. Jacks are up.
Two questions:
Is it ok to drive it like this and get it when I get there? Obviously would not use jacks.
Can I bypass the alarm that goes off as soon as I put in drive/release the break
Thanks
  • If the rig has slides they may not work.
    If jacks are up, you should be OK. Should be able to pull the fuse for the jacks to kill alarm.
    Bet it is a hose!
