- Big_JimmyExplorerThank you Doug
- Just remove the 2 screws that hold the 6 way switch in place. It will pull out enough to remove the backside quick release plug. Doug
PS, you still have to do everything you asked for in a previous post - Big_JimmyExplorerThanks for the feed back, I’m not taking out the base so I need to unplug the electrical connector from the outside hand control, large style plug , same size as the hand control, 3-4” long 1-2 wide.
- hotjag1Explorer IIOn our Tiffin in the signature, the seats(if I recall) have a 3 or 4 wire harness with a plug disconnect that is right underneath the seat beside the swivel base. Easy disconnect on ours.
- Sandia_ManExplorer IIJust had to remove driver side flexsteel chair on our Monaco to work on some wiring under the dash, plug is about an inch square more or less, easy to unlatch and snap back together. Although I didn't give much thought to the size of the plug when removing or reinstalling our 6 way captains chair, it was relatively small compared to other plugs that abound the breadth of our coach.
38,782 PostsLatest Activity: Aug 23, 2026
