ClassAGeek wrote:
Executive wrote:
Do us a favor...when the resto guys get there, ask them if you should use heat or A/C...there seems to be two opinions as to which is correct. Ask the pros...let us know the outcome.....Dennis
Good one. I will ask.
I would run both heat and AC. Warm dry air is what you need to pull the moisture out of the carpets and wood etc. Heaters provide the warmth, AC provides the dry. In any case the pros will probably have a dehumidifier the size of a refrigerator that will both heat and dry.
