workhardplayharder wrote:
Don't run heater run the AC.
Actually, the opposite.... run the heater! I made that mistake when having our home carpets cleaned in the heat of a summer (years ago). I, too, thought that running the air-conditioning would help them dry faster... .it took absolutely forever.
I turned off the air and let the upstairs heat up.... they were dry in no time at all. The heat will dry the carpets.
To the OP, I would contact my insurance company too. I have a feeling the carpet will need to come up to see if there was any floor damage.
Let us know what happens.
MM.
Do what you want. I would run AC. The AC will reduce the humidity and cool the room/RV. Here in south Florida there is plenty of heat and humidity-the perfect breeding ground for mold. Mold will not grow in a cool low humidity environment. Turning on the heat will increase the humidity and heat the room/RV creating the perfect environment for mold (at least here in south Florida.
As I said in MY situation, I ran the AC to no avail. I had wet cold carpets. Once I let the room heat up to over 90 degrees, the carpet was dry and shrunk back tight.
I guess it depends on your situation and climate. If I had a flood, which we didn't, I would pull the carpets up to dry the floor. I would let it stay hot until the wood was dry.
MM.
