erniee
Dec 07, 2013Explorer
Most coaches are configured with the same installation practice. I usually cut the carpet just close to the edge of the slide. This gives maybe 3-6 inches of carpet under the slide. Sometime, with a pair of channel locks, you can start at the end of the slide and pull the carpet and pad from under there. Remember, this is a horizontal pull and not as effective, but doable, as a verticle pull.
38,769 PostsLatest Activity: Apr 03, 2026
