navybanker's avatar
navybanker
Slide Floor Replacement
The floor in the bedroom slide is rotten in the back corners due to leaks. I am taking to dealer next week and need to know what I should require as far how they repair it. I am going to say replace with exterior grade plywood. What else should I mention and check on. The side walls may need attention as well. The leaks have been worked on without success for several years by myself, dealer and a mobile RV tech without success. I think the leaks are fixed but will mention the 4" strip needs to be redone correctly. This should be redone during the repair. The rotten wood was found after the bedframe came loose from the back slide wall so the bedframe needs to be reworked. Anyone have any cost estimates? I have heard it will be around $2,000 just for the slide floor! Thanks for your advice.
