sailor_lou wrote:
mikey52 wrote:
I think it is a nice thing to have around. I can see using it for your own coach and even allowing friends and others to weigh their coaches to insure they are within limits. Good for you.
I agree and I still don't get why some people have the constant desire to tell everyone how to spend their cash. Using that kind of logic it's a waste of money to even own an RV, hotels are much cheaper.
Lou
05 Travel Supreme Envoy
Didn't tell anyone how to spend their money. I said when it becomes that much work for me I'd rather spend my time on other pursuits.
Pirate wrote:
azdryheat wrote:
Sounds like a waste of $340 and your time. Cat scales are cheap.
Cat scales won't tell you that your right side is 600lbs heavier than your left side, something my last 4-corner weigh-in did.
Seriously? A 4 corner or side to side one time will tell you how even the sides are as manufactured. You mean to tell me that you can't figure out that you overloaded one corner by 600 lbs, that's a lot of weight.
It's not rocket science. Let's say you have a rear axle rated for 17.000lbs. At full weight your tires require 100 psi. So 1 side is 600lbs heavier. That's a difference of 3.5%. So what do you do? One set of tires(side) get's 101.75lbs and the other side get's 98.25lbs. You really think that will make a difference? Depending on which side of the MH is facing the sun the heat from the sun can make a lot bigger difference than that.
Morning temps versus afternoon temps will also affect tire pressure a lot more than that 1.75lbs. Driving from a northern state in the winter to a southern state, same result. Speed, a big difference tire temps. I could have used a higher GAWR but that would make that 600lbs even less significant.
Do what makes you comfortable, feel good, but I really think some overthink this. Is tire pressure important, of course it is. How accurate is your gauge? If it's digital, maybe it will read to .5lbs. Other gauges, how good are your eyes?
Set your tire pressure based on the manufacturers recommendations and weight. A 5% or even !0% difference ain't gonna make that much difference. There are just too many other variables at play, outside temps, speed, etc.
Just my opinion, probably only worth what you paid for it. But, in 48 years of driving I have never had a tire blowout on a car, boat trailer, camper, TT or MH. Am I lucky? Sure, you can can do everything possible and still have a tire failure, stuff happens.
