Thanks for the head's up. Question for you Sundancer, was the adhesive failure the only thing that you found wrong? I don't think she'll be exposed to extreme cold weather for a long time. I do however fear that heat maybe an issue. Knowing what you know today, would you have used a standalone adhesive aside from the strips? Do you think it would've made a difference? Thanks for your insight.
sundancer268 wrote:
I have the click together Allure Ultra Flooring and do NOT recommend it in colder climates for storage. My planks have pulled apart on the narrow end once the temp gets in the 30s. I partly tore up the floor and super glued the narrow ends together and reinstalled. The following winter it pulled apart in an area I had not glued. This spring I will remove the remainder and glue all the narrow pieces together.
