I have a 2011 Fleetwood with a V10 gas engine and tow a CRV. The RV has 40,000 miles. At what interval do you change the RV transmission fluid ? Does anyone change brake fluid this early? How about c...
Since brake fluid absorbs moisture, even when parked, mileage is not really the factor to use when changing it. Some recommend every 2-3 years as being a better maintenance schedule. Since you live in a high humidity area of the country, closer to 2 years may be more prudent for brake fluid.
