Edd505
Mar 09, 2020Explorer
I had the same issue last year and messed around 2 days. The Theford will tell you it can not be put back in & I watched YouTube and researched. I replaced the Theford Aqua Magic 2 with the Dometic 310. After about 9 months use I would never go back to a Theford, the 310 actually flushes the bowl all the way around. About $120 with every thing you need. I did add a shut off valve in the water supply behind the bowl.
38,782 PostsLatest Activity: Sep 02, 2026
