Yankee_Clipper
Feb 09, 2017Explorer
The manifold rarely cracks, usually it warps with the heat and breaks the cap off the bolts. Most common on the passenger side rear (#8 cylinder). The worst case is a crack in the cylinder head, which requires head replacement.
One note: when mine warped and broke the bolt, I was able to easy-out the bolt after taking off the warped manifold. Found a replacement cheap, but hold on to your wallet when you find 1) the bolts cannot be re-used and 2) a replacement set costs about $150.
Otherwise it's a pretty easy DIY project. HTH
