blownstang01
Jun 14, 2017Explorer
First you have to find out if your unit has remote entry. The easiest way is to enter the programming sequence and see if the vehicle responds. You can find instructions for the different years here >>>> http://www.keyfobprogram.com/category/ford/
Once you find out it has it by going into "program mode" you can buy the corresponding remotes from either Ford or other aftermarket retailers..personally I like Ford Originals.
Or you can buy the stick on push button remote as someone said, here >> https://accessories.ford.com/electronics/keyless-entry.html
All is not lost if the cab didn't come factory equipped, as others have said any stereo place should be able to install an aftermarket unit. Good Luck !
38,782 PostsLatest Activity: Sep 02, 2026
