Semi Retired Grandpa wrote:
timmac wrote:
427435 wrote:
I really don't understand all the bitc+++g. If you are unhappy with the noise levels, add some insulation to the dog house. If you are unhappy because it kicks down too easy, learn to shut it off on hills and just use the gas pedal at a moderate setting a so it kicks down at a slower speed.
I've learned to put my foot on the throttle to over ride the CC when going down hill to pick up some speed. I will also kick it out of O/D a little early when climbing a hill to ease the shift and maintain the desired speed.
In any event, the CC on my old F53, pulling a 5000 lb toad, works as good as I can expect.
Its not that we are bitc+++g just pointing out that CC have not gotten better over the years as the rest of the chassis, same as with our Nissin truck, every time it gets to a hill the CC shuts off, they can develop a smart CC that knows its in the hills and slows down the speed and just down shift 1 gear and not 2 gears, when I am on a long hill and maintaining 45 mph I can do it in 4th gear but if I put the CC on it wants to go to 3rd gear.
I think todays CC is the same as 30 years ago, nothing has changed in this department.
So true with the Ford - our SUV (car also) shifts down one gear at a time - the change barely discernible. We can travel up and down Oregon's mountains w/o having to adjust the CC. BTW - the car also senses the speed of the vehicle in front and adjusts speed accordingly. Very relaxing - a far cry from the Ford where even the slightest grade too often results in a dramatic change in engine RPM's. Far past time for Ford to bring its CC up to today's level.
You REALLY should pay attention to what is NEW and not what WAS. Ford's new vehicles do have "adaptive cruise control". Spend a little of your free time researching first.
Ford adaptive cruise controlUnfortunately not available on Super Duty's yet
