Rolin
May 04, 2014Explorer
The seat in our E450 was too low and would not move back far enough.
2each - two inch square tubes, drilled holes on both sides.
- Side one, required additional hole to accommodate a bump in the base.
- Attached side one to the existing base.
- Side two holes were drilled back 1 inch and attached to the bottom of the seat.
- Painted the tube black so it is not noticeable.
Result: Seat 2 inches higher and 1 inch further back.
Makes it much easier to move back and forth between cab and coach and provides more leg room. Might drill second set of holes 2 inches back in the future, but this set up is ok for now.
38,766 PostsLatest Activity: Jan 10, 2026
