theoldwizard1 wrote:
Does this happen when driving down the road ? It could be the direct drive clutch of 4th gear causing the problem.
You don't state the frequency of this problem, but here is something to try. Drive with the overdrive turned OFF and see it occurs. If not, you have found the culprit.
Don't condemn the transmission right away. It could be a bad electrical connector or a bad solenoid.
Yes. I drive with the OD off when driving up or down the Cajon Pass and it happens then also. Idle. Driving. It's strange. However, I think we're onto something with the post further up that I responded to.
Thank you for your response. I feel a little less blind on this matter.
