I am hoping to do the test drives tomorrow as it looks like the only day without ice. I did tell the dealer I wanted to test drive them back to back on the same course and they said that would be doable. I will have to look at a map and see if there is a CAT scale nearby, that would be very interesting, particularly the front end weight difference.
I am sure you have all been through this but dropping 50k on something without being positive is scary. I knew what floor plan I was looking for and that I wanted the smallest unit possible but most dealers had zero inventory in the size I was looking at. I finally found this dealer that had several but they are a 3 hr drive each way so the back and forth is a killer.
