Baja_Man
May 20, 2016Explorer
Quote"
This is what you will need (if you buy the case of 12 quarts Mercon SP, you will
be left with about 2 quarts when done with flush and refill):
Quote"
You must have performed a drain and fill....as a flush requires a heated machine. I believe this trans holds closer to 15 qts total. The drain and fill is when the pan is dropped and filters are changed but no flush occurs.
Did you install a temp gauge?
Quote"
38,769 PostsLatest Activity: Mar 31, 2026
