camperdave's avatar
camperdave
Ford E450 q's
I'm looking at used class C's in the 29-30 foot range (I want couch, dinette, and a walk around queen) and have narrowed my search to an older V10 rig due to cost factors. I am somewhat knowledgeable about the V10 as my current tow rig has an early version (1998 Van). I believe there were several updates in the early years, then Ford settled in with the same V10 that is still being used today in the E450's. I do not know exactly what year the final version went into service though! Somewhere between 2000 and 2003 I think.
My current thinking is to limit my search to whatever chassis will have the most current engine. Am I correct that from 200(0-3?) to point to today, there have been no further updates of the E450 V10? Is there a specific chassis year that can guarantee the most updated engine?
My other question is about the trans. I know the torqshift 5spd came out around 2005 (probably 2006+ motorhomes). I am of the thought that the 4R100 is 'good enough' and I'd let price/condition dictate the purchase at this point. As far as I am aware, the 5spd is most notable in its ability to downshift in the hills, and has lower 1-2 gears, but I believe final overdrive is the same as the 4R100. Agreed?
Final q - the 2008 update was just the front suspension/bodywork, is that right? Something this new would be a reach financially, I'm feeling like I'd rather have the older front end anyway (I think it looks better). Any other improvements to the updated (08+) E450 that are noteworthy?
Thanks for any advice!
  • j-d's avatar
    j-d
    Explorer II
    Essentially same V10 in E450 since 2000.
    TorqShift nicer than 4R100
    New Six-Speed presumably nicer
    2008 incorporated LARGER FRONT BRAKES and a better front sway bar
    Somewhere along the line, eliminated the driveshaft parking brake in favor of "Drum in Hat" rear disks
    Service brake is disk but parking brake has its own little drum within the rotor and a set of little brake shoes
  • Hi,
    Wikipedia has a pretty good page on the Econoline with engine, transmission, and model update info. You can also look up the V-10 there, too.
  • Hi,
    My E-450 is from 2005 and has the four speed transmission. I'd look for the 5 speed.
