John_Wayne
Apr 14, 2014Explorer II
I can get to mine with out removing anything. It is on the drivers side of the e-brake unit and above mid line of the unit it's a plug screwed into the side of the unit. I find a small pump type oil can works best with a flexible spout. Only takes few Oz. so don't pump a lot in to began with. As it starts to run out of the hole put the plug back in a spry down with brake clean.
The plug takes a 17mm socket
