msmith1199's avatar
msmith1199
Explorer II
Apr 25, 2016
Ford F-150 as a toad?
Anybody using one of the new F-150's as a toad? I currently have a 2006 Dodge Dakota as a toad. It's been a good truck but I'm looking at replacing it. It is a fairly heavy toad but my 35 foot DP pulls it just fine. I can feel the extra weight back there with the Dakota versus when I had my Wrangler, but I've towed this thing cross country including over the Sierra's and the Rockies and it has done just fine.
Dodge doesn't make the Dakota anymore and of the towable four-down trucks available out there the choices are slim. I was mainly looking at the Chevy Colorado as it's about the only smaller truck that is towable four-down. But then I took a look at the F-150. I didn't really want a full size truck, but the new F-150's are pretty light and they are actually cheaper than the comparable small trucks probably because they sell so many F-150's.
According to the Ford website the weight of the configuration I'm looking at, should be 4782 pounds. That is the extended cab 4x4 model. My Dakota weighs in at about 4500 pounds according to the scales at the dump. So I'm really only adding three or four hundred pounds. The Colorado is about 4400 pounds in the configuration I'm looking at. I've put my 450 pound quad in the back of my Dakota and towed it behind the motorhome and couldn't even really notice that extra weight. So I'm thinking the F-150 will tow just as good as the Dakota, plus I get a nice full size truck for about the same as I'd pay for a smaller truck if I went with the Colorado.
Anybody towing the new F-150 and have you had any problems with it?
  • gtschulz wrote:
    I tow a 2015 F150, 4 wheel drive. Not a problem.
    Your motorhome is bigger than mine, but the engine isn't much bigger. I have the 330hp Cat and you have the 350hp Cat. I'm thinking the few hundred extra pounds shouldn't make that much difference.
  • Effy's avatar
    Effy
    Explorer II
    I think Holstein does. Maybe look up some of his posts, I think he wrote some stuff on the subject a while ago.
