Rocket9k
Aug 28, 2020Explorer
Thanks for the replies! I did not note in my original post but should have: I just replaced the radiator, hoses, water pump, and thermostat. I found the original radiator to be leaking and internally obstructed with crud.
I had an issue with it running all the way at the high end of the temp scale constantly, and the new radiator cured that problem but I'm still concerned that the fan may not be engaging properly. It will not engage during normal driving until the temp goes past the L in Normal. Occasionally it will engage at a traffic light but quickly We plan on taking the rig on many out of state trips, possibly with a toad, and I want to be absolutely sure the cooling system is at 100%.
