RLS7201
Aug 29, 2020Explorer II
When my 95 F53 460 fan clutch failed, I replaced it with This clutch from Oreilly Auto.
Price is right and it has worked correctly for the last 40,000 miles. I hear my fan clutch engage and disengage all the time and my temp gauge doesn't move unless the engine overheats.
To change the clutch, work through the dog house. Do not remove the belts or fan shroud.
Remove the two hoses going to the throttle body, for room to work.
Loosen the 4 bolt holding the fan to the clutch but don't remove them. Remove the 4 bolts holding the clutch to the water pump. Slide the whole assembly into the fan shroud, carefully. Remove the 4 bolts you previously loosened. Remove the clutch. Find a 1" stud and insert it in one of the water pump bolt holes. This will help you align the clutch holes to the water pump holes. Put it back together.
Richard
Richard
