RLS7201
Sep 02, 2020Explorer II
Rocket9k wrote:
Richard, it looks like you were moving the spring around considerably on that thing. Is that a Hayden 2799? From what I understand, 1/8" gives you approximately 10 degrees difference in engagement temperature. Did you find you had it move it more to get a change? It's going to be 84 degrees here tomorrow, so I may go wring its neck a bit and see how it does.
To answer your radiator question, I have an all aluminum replacement from superior cooling, as well as a complete banks system. It seems to do the job very well. The temp gauge stays between the O and M on the ford NORMAL gauge (190-210 according to my IR gun) which is well within acceptable temperature range for the trusty 460. If I am out of overdrive in 3rd gear going down the highway at 65-70 the temp will goto A, WITH the dash A/C on. I am sure if i'm climbing with a load on it will go beyond that, which is why I want to be sure my fan is working properly. Where exactly did/does your factory fan clutch kick on if I may ask, on your \__NORMAL___/ gauge?
I may have no problem whatsoever, but I would like to be 100% confident that I do not before I venture out on long runs.
Once up to temperature my gauge never moves off the "O" unless the the engine overheats. The clutch kicks in and out and the gauge don't move. Throughout the years of being on various RV forums, I typically see 460 issues such as yours, with replacement radiators. Do what you must.
Richard
