Keily
Nov 17, 2014Explorer
Ford F53 Question
I have a new motorhome , 2014 Adventurer 37F with the F53 362-hp 6.8l V10 Triton engine, TorqShift 5-speed automatic overdrive transmission with tow/haul. Mileage is about 6000 miles. This is my se...
This is my second motorhome with the same type of engine, it was a 1999 F53 with the Ford V10. My question is regarding the tow/haul feature. In the past I always used the tow/haul when going down steep hills as an engine brake, when activated in the older engine the engine would rev up a bit to maybe 3000 rpm(depending on how steep the grade was) but the overall speed of the mh would slow down. I have noticed on the new mh, when I activate the tow/haul when going down a steep grade, the engine rev's increase quite a bit more and there a lot more of a roar coming from the engine. As the vehicle speeds up the higher the tach goes and the louder the roar, so much so I usually de-activate the tow/haul button, and use the brakes to try to slow down. Does anyone know is this normal for this new engine, I am afraid I might be doing some harm to the transmission or the engine if I leave the tow/haul activated.
Does anyone else have the same thing happening?, maybe this is normal and I got nothing to worry about.
Thank you in advance for your advice.
