RLS7201
Jun 01, 2012Explorer II
str8shooter_mn wrote:
I keep reading about a recall. Not sure what it is. Please enlighten me.
Have checked connection at master cylinder. Disconnected and reconected several times. Seems ok to me.
Where is brake light switch located? Doubt it is problem but will check anyway.
Shooter, The switch is under the dash, where you have to stand on your head and use a mirror to see it. (not fun) It's where two pieces of the brake linkage join with a pin.
The recall was because of brake fluid leakage from the secondary cruise control disengage switch, located on the master cylinder. Ford added a short wiring harness with a fuse to reduce chance of fire.
Richard
