mowermech
Apr 19, 2013Explorer II
The same problem in mine turned out to be the plastic wire harness connector in the tilt steering column. The turn signals would only work with the column all the way forward, and the cruise control did exactly what the OP is dealing with.
I had the connector replaced, and all problems went away.
38,782 PostsLatest Activity: Sep 10, 2026
