rk911
Aug 31, 2016Explorer
K Charles wrote:
We tried a few with a gas and a few with diesel. I didn't like the was the ford handled. We ended up with a 35 ft Winnebago an a workhorse chassis. Getting to big and still have the lighter chassis I what I didn't like. Look at the carrying capacity and see how much is left over after they put the house on. Some are right at the limit before you start putting anything in it.
that can be true. when we were searching for a new MH back in 2000 one model that we were very interested in ended up being overweight on the rear axle the moment we stepped inside. as a result I am very weight conscious.
with a full load of fuel, fresh water, lp, food, clothing, supplies, people, pets and stuff on our 2016 38Q-U1 F53 chassis I have just under 900-lbs of payload left on the rear axle and and about 1500-lbs on the front. there are just the two of us and Maggie the beagle.
but the OP would be wise to not depend on the sales critter or the sticker in the closet for weight information (if buying new) and instead insist on taking the MH to a certified scale to determine the empty weight. the wet weight can then be calculated. our dealer was happy to do this.
the empty weight of our specific MH was 6800 on the front (2200-lbs payload) and 14,000-rear (3500-lbs payload). the measured wet weight (full tanks of fuel, fresh water and LP) was 6295 on the front (2075-lbs payload) and 15,100 on the rear (2400-lbs payload). the actual wet weight was roughly the same as my calculated wet weight.
