Just acquired a 2014 31' Newmar. How do I remove the hub caps on 19.5 tires? How does the "Tow Mode" function. Haven't got the books. Thanks in advance for assistance.
On a 2014 the tow/haul button will change the way the transmission shifts,but will let it go into overdrive.Its very usefull in hilly driving as when you tap the brakes on a downhill run it will downshift.The earlier fords had an overdrive button that locked out overdrive.If the hubcaps are the stainless ones with fake lug nuts two of the nuts have dimples on them.These two can be unscrewed and the hubcap will come off.
