Just acquired a 2014 31' Newmar. How do I remove the hub caps on 19.5 tires? How does the "Tow Mode" function. Haven't got the books. Thanks in advance for assistance.
jy is correct...but allow me to add to that. Tow/Haul not only changes the shift points of the transmission, allowing it to hold a gear longer for towing or hilly climbs, it also functions as a "transmission brake" when going downhill. jy mentions this as well.
I recommend going to Ford website and you can download a PDF of the chassis owners manual, which should be a must for a chassis you are not familiar with.
