Carvin_Marvin
Sep 04, 2019Explorer
Ford Questions
Just acquired a 2014 31' Newmar. How do I remove the hub caps on 19.5 tires? How does the "Tow Mode" function. Haven't got the books. Thanks in advance for assistance.
Horsedoc wrote:
Depends on the type wheel, but if the caps look like chrome lug nuts (about 8 of them) there will be two that hold the hubcap on. Look carefully to determine which is fake and which holds the caps on. Somewhere in your rig, there is likely a T handle tool with a socket fits these "nuts". Carefully loosen the two 'real' nuts and the cap should come off. Good news is these two are 180 degrees from each other.
