Carvin_Marvin
Sep 04, 2019Explorer
Ford Questions
Just acquired a 2014 31' Newmar. How do I remove the hub caps on 19.5 tires? How does the "Tow Mode" function. Haven't got the books. Thanks in advance for assistance.
mleekamp wrote:
jy is correct...but allow me to add to that. Tow/Haul not only changes the shift points of the transmission, allowing it to hold a gear longer for towing or hilly climbs, it also functions as a "transmission brake" when going downhill. jy mentions this as well.
I recommend going to Ford website and you can download a PDF of the chassis owners manual, which should be a must for a chassis you are not familiar with.
