CloudDriver wrote:
I plan to take some pictures and write up my experiences in getting this done.
@Drew: NOW I know when I'll change the plugs in our 2002 chassis year E450 V10. AFTER CloudDriver posts his Step-by-Step process!
NOBODY does things more carefully and NOBODY documents a project better.
Thinking I'll just play the thread like a PowerPoint and if I'm close enough, the plugs and coils might just change themselves. Probably have to take the dog house out first, though.
@CD: Your coach is a 2003, and so is ours. Ours is 2002 chassis year. Which is yours?
The shop I talked to said a key factor is being sure the new plugs are started true in the threads. I'm not worried about you, but the shop heard of others putting the plug in the socket and extension then driving it with an Air Tool! They told me spraying a penetrant won't help because the seated plug won't admit it to the threads. I want to be sure the cavity the plug sits at the bottom of, is CLEAN before I loosen. Even if I have to make a long nose adapter for my blow gun.
I've heard of breaking the plug loose then applying Blaster or the like then letting it soak. But I don't see any need if the plug spins out once loose.
Sounds like you're working on a cold engine. Please let me know if you think HOT would be any benefit. I'd really rather not do that,and it's starting to sound like it'd be cold anyhow, by the time I took enough off to get at very many of the plugs.
