SFVdave's avatar
SFVdave
Ford V-10 MPG getting worse, dirty MAF?
My 2004 Ford V-10 has MPG dropping since 2006. As my engine was getting broken in, you'd think the MPG would go up slightly, mine dropped. Not sure about the corelation, but that's about the time I changed from the paper air filter to the K&N. It did seem to have better air flow. I cleaned and re-oiled it once at around 20,000 miles as it look dirty. Then about 2010 when it had about 40,000 miles, I bought a new K&N air filter. Kept the K&N air filter in til last month.
After reading about the fact that oil from the K&N filter can make your MAF sensor dirty and cause engine performance to decline, I switched back to paper air filters. My MPG still is low on my last trip. So I read and watched videos on YouTube on how to clean the MAF sensor. I followed their example and bought the CDC MAF cleaner. It was very easy to disassemble the air intake and remove the sensor. It was very dirty, I am surprized there were no trouble codes indicated. Cleaning and reassembly were just as easy. Now I will just have to wait for my next trip in August to see if there is an increase in engine efficiency. I have been usinbg SeaFoam and injector cleaners on many occassion, but that didn't help.
For those of you wondering what my MPG was and is, originally, I was getting 10.0-10.3 when I first got it. It slowly dropped down to 9.5-9.8 on the same route to the Sierra Nevadas. I has continued to drop over the years and now I am getting 8.5-8.9. It's a smaller E-350.
  • OK, maybe the change in the fuel caused the MPG drop and yes, I have added weighted things to the MH and the remaining CCC is probably zero. Well, it only cost $8 for the MAF cleaner, same a In N Out double double with fries and a shake. Maybe it will run better and cleaner.
  • Hi,
    A mileage drop of about 10% (10 mpg down to 9 mpg) is what I found as the "real gas" has been increasingly replaced with this ethanol junk. My 8.1L used to give consistent mpgs in the low 8's when I bought it in 2004. Now, it runs low 7's on the same trips.
    It could be related to your MAF sensor, but I observed roughly the same drop in mpg during the same time period on an entirely different drivetrain. You decide.
    Let us know if you find a way to restore your mpgs.
    ~Rick
    On Edit: overbrook...you beat me to it! I could've just done a "X2"! LOL
    Prior to 2006, you were likely running a non ethanol fuel. But from mid 2006 on, e10 ethanol is what most of us are forced to fuel with.
    Assuming you were running straight gasoline and were then forced to switch to E10 (gasoline cut 10 percent with ethanol), your mileage will drop. The big question is by how much.
    The Environmental Protection Agency says E10 lowers mileage approximately 3 percent, but most real world reports say the mpg drop is closer to 10%.
    That may not be the only reason you are seeing your mpg drop, but it could be a major factor - considering you saw the drop around the time the EPA mandated e10.
    Bill
  • I calculate my gas mileage by do I have enough money to fill the tank. If so, I'm good to go. Otherwise I'd be tent camping with a smart car:B. I'm getting about 7 mpg on good days. 102 degrees today so ran the generator all day. Probably down to 4 or 5. When I filled the tank today I still had money left over for beer.
  • Your weight has likely increased in seven years as you accumulate rugs and mugs, doo-dads and conveniences. Weight affects performance.
