haste_maker
Jul 11, 2020Explorer II
Ford V10
This question is for those that have a Ford V10 in a class A. I have a 2007 Allergo 32BA with the Ford V10 that only has 36,000 miles on it & I took it to mountains of Western NC this week, and it see...
carringb wrote:camperdave wrote:
I know everyone says the V10 likes to rev, but man I just personally can't let myself keep her above 4k rpms for any extended time, it's just so.. well.. revvy I guess.
If it makes you feel any better, I regularly hang out near 5,000 RPM, sometimes for 15-20 min at a time. When pulling heavy loads over the mountains, I just lock in low gear (2nd on mine, which is equivalent to 3rd on the 5R110) and let it hang out there. Then when I need to ease up for tight curves or slow traffic, i immediately catch right back up where I was (usually 58-62 MPH). My combined weight is 22-25,000 pounds. I replaced the first motor at 458,000 miles because of a warped a valve seat letting it run lean after the fuel filter plugged (my tune contributed, but my tuner took a bath that same weekend so I couldn't go back to stock). I also had the Banks PowerPack on since around 120,000 miles. All other cylinders still had in-spec compression, and the cross-hashing was clearly visible when I scoped it! And my 4R100 is still original with 483,000 miles!
