haste_maker's avatar
haste_maker
Explorer II
Jul 11, 2020
Ford V10
This question is for those that have a Ford V10 in a class A. I have a 2007 Allergo 32BA with the Ford V10 that only has 36,000 miles on it & I took it to mountains of Western NC this week, and it seemed weak on pulling power, I tried to keep the RMP's below 4000, and at time's I was down to 40 mph, I was pulling a 2003 Honda Element...it this normal?
  • 40 MPH with a dinghy is typical of what we just did in the mountainous section of I-70 in CO. I was trying to keep the RPM at 4200 but based on posts maybe 4700 would have been better. Worst grade was this trip I-70 from Dillon to Eisenhower Tunnel, 12 miles of 6%. Don’t like straining the tranny like that as it was making some strange whining sounds the last mile or so (5 speed Torqshift). May unhitch the dinghy if we ever do that grade again.
  • That engine makes its peak torque at 3,250 RPM. It makes peak HP at 4,750. To climb a hill in a hurry you need more HP. So, by staying below 4,000 RPM you are giving up HP that the engine could be making if it was spinning faster at 4,750. However, many people say the "best" RPM to pull a grade is at peak torque. At that RPM the engine is most efficient at hill climbing but not necessarily the fastest. So, take your pick, you can have speed with RPM or you can have efficiency and possibly cooler temps at peak torque but you can't have both.
  • That is where I try to keep mine at on rpm and 40 mph going up and in a lower gear.
