haste_maker
Nov 23, 2022Explorer II
Ford V10
Has anyone had to replace the throttle body on a V10? And if so what year was your unit & the amount of miles..
haste maker wrote:I would check the senor first as Matt suggested and then spray some throttle body cleaner like CRC and see if that fixes the problem. There is also an IAC valve (air idle control valve) that sometimes sticks that can be cleaned also.Gjac wrote:
What makes you believe it needs to be replaced?
It will only idle & the code reads throttle body stuck.
